Automatic to Manual. Need tips
Old Sep 13, 2012 | 02:27 PM
brickman12's Avatar
I have a 92 camaro rs with a 30t tbi injection. It has the 700r4 transmission. I have really wanted a stick shift car for a while but always wind up with automatics which is my fault for not looking more. Would it be worth changing the 700r4 to a t5 manual? Or is there a better transmission that i should choose? alos is this a hard swap and what would i need to complete this transformation?
Thank you!
Old Sep 13, 2012 | 03:09 PM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Re: Automatic to Manual. Need tips
To me it would not be a hard swap. To you? How are you with the mechanical work and some cutting and drilling and some electrical. If that is basic to you it should not be a big problem.
Unless you are hard on the car a T5 should hold up but a T56 would be better.
For a T5 swap get the pedals and hyraulics, bellhousing, trans, flywheel clutch etc for the T5 and except for the drilling, shifter hole cutting, and electrical it should basically be a straight bolt in. For the wiring look at bottom of page 3 on the T56 swap sticky. It covers the auto to manual wiring.
For the T56 swap read just the first three pages. It covers everything real well.
Old Sep 13, 2012 | 03:26 PM
brickman12's Avatar
Thanks for the info. Would a manual transmission help the acceleration better than the 700r4.
Old Sep 13, 2012 | 05:13 PM
91phoenix's Avatar
One thing other than the tranny that would help alot is the rear gear choice. From the factory most had real poor gear choices for a performance driven car. With a T56 and the .50 overdrive you can use a 3.42 or 3.73 rear and have good acceleration and fuel mileage. These cars from the factory had gear ratios like a 2.73 with the V8 and is not very good for performance.
Lbibb
May 5, 2016 12:00 AM
Fireslash
Apr 11, 2016 06:43 PM
jrdturbo
Mar 31, 2016 02:58 PM
loud91rs
Oct 5, 2015 10:05 PM
bjpotter
Oct 4, 2015 07:48 PM
