Mystery 700R4 (Need Advice)
I recently got a 85 z28 camaro with a 700r4. It's a basket case but anyways, the trans shifts EXTREMELY hard and I think it must be from a drag car. The wiring was extremely crappy (one power wire from the starter that went all the way back to the tail lights and powered everything from the fuel pump to the alt. exciter) Anyways, there was a single 12v ign wire run to the 700r4 plug.
What's the best way to tell if the 700r4 has a lockup converter still? If it does, I don't believe it was working when I drove the car home.
The trans shifts EXTREMELY hard and blows the tires off the car on the 1-2 2-3 shift.
I've done trans work before but it's a different animal with a trans that's had work done to it. Need to establish a plan of attack to make this car street-able (and safe). I'd like to hear some opinions from some guys with experience for the proper course of action.
I'm thinking a full manual reverse valve body, a manual shifter, a TC wiring kit (if I have the right converter). Good idea/ Bad idea?
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: Mystery 700R4 (Need Advice)
Currently I have the car apart to fix some of the previous work but I'll try this once its back on the road before diving into it.
What's the easiest way to see if I have a lockup/nonlock up converter - just wire a switch into it and try it?
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Those hard shifts make me think of a B&M Shift Kit. That's exactly how my original 700-r4 performed after I had it installed.
I believe '85 makes it the older shell which isn't as strong if that's an issue.
Other than that I'm a big believer in the TransGo kit.
Dragonsys
Sep 25, 2015 03:51 PM
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
