5speed vs 6speed manual?
Car: 1991 Z28 Convertible
Axle/Gears: 3.23 with Eaton posi
Which is better choice? Aftermarket 5 speed or 6 speed?
I currently have 350/auto combo. Plan to make 350-400hp. Its just a cruiser with some "occasional" spirited driving in the city. I want to switch to a manual trans just because I like it more.
I used to own a 2000TA with 6 speed. I rarely got into sixth gear and it was only cruising on the highway at 70+mph.
Any thoughts on aftermarket 5 or 6 speeds with great grear ratio's (I really dont know what the optimum gear ratios would be for a cruiser/speedy city driver).
Any thoughts on going with 5 speed vs 6 speed?
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Re: 5speed vs 6speed manual?
Im going to just tell you right off that if i had to do it all over again i would have just thrown a t56 (6 speed) in my car instead of the tremec tko 5 speed thats in it. Its been nothing but headaches. There is more to leak on the tko and ive had leaks, its a harder swap in these cars with more to modify or expensive parts to buy. With all that said however, its a very strong trans that can handle a ton of punishment. Its notchy shift takes some getting used to but its not terrible. If your planning on making the power you say then the stock t5 will not do and the only real manual options are the tko or the t56. Just go t56 and dont look back.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
The t56 is a bit larger and heavier, but it still fits better and can be swapped for less money since you can get used ones from a lt1 year 4th gen for reasonable money where-as you will be hard pressed to find a used tko for anything resembling cheap.
Engine: 355 TPI
i will agree with all of this. The I have a tko600 as well, its a great trans, strong as hell and has a good gear selection. It need some more indepth fabrication to fit it properly in the car, but it will at that point fit with the stock crossmember, which allows a lot more ground clearance and strength than the typical t56 crossmembers will offer.
