Royal Purple rear end fluid?
Car: 1984 Z28 HO
Engine: GMPP 350 HO
Transmission: 700R4 w/TCI streetfighter kit
Axle/Gears: 3.73 28 spline Eaton posi
Hi all.Can anyone tell me if I use royal purple rear end fluid that says it's good for posi rear ends,do I still need gm posi additive.I have an eaton posi with 3.73 gears.Thanks in advance for your help.
Re: Royal Purple rear end fluid?
I have an Eaton as well . Its been a few years , but I think what I did as add one small bottle of that slip additive and I think royal purple claimed to have that stuff already in it . I broke in the posi with regular fluid then put in royal purple when it was suggested I change it . I like royal purple diff fluid , so much so I wanted some for my trans , but read people say it's no good . oh well
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Although I don't have a posi, I still think every diff with a clutch or cone posi system should be using a posi additive. It's always nice to upgrade to a 75w90 synthetic oil while you're at it but the synthetic oil by itself normally isn't good enough for a posi.
Royal Purple does claim that the limited slip additive is already added to their Max Gear synthetic oil so according to them, you shouldn't have to add any more. Their regular 80w90 oil doesn't have the additive.
I run all Lucas oils in my race car.
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Back in 2010 with 58k on the odometer. I put royal purple 75w90 with gm limited slip additive # 1052358. its still OK with 88k and has been daily driven all year round.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Navy8125
Aug 17, 2015 01:29 PM
