700R4 Query
Old Sep 26, 2012 | 04:21 AM
Lennyp's Avatar
Car: 1987 IROC Z
Transmission: Automatic
700R4 Query
Hi, I have an issue with my auto box. Reverse is not selecting. Well I say that but it makes a whining noise and sounds like a solenoid works or something but i get no movement. Could this be a selector issue or is it likely I need a rebuild? Any help will be most welcome! Alena
Old Sep 26, 2012 | 06:51 AM
87zjeff's Avatar
Axle/Gears: '01 3.42 10 bolt
Re: 700R4 Query
are any other gears having issues. if you put it in drive does it still go forward. does it go back into park after being in drive since this issue started. if not it is likely a shift cable issue.
Old Sep 26, 2012 | 12:44 PM
Lennyp's Avatar
Car: 1987 IROC Z
Re: 700R4 Query
Thank you, I can get forward movement in all gears, there seems to be stiff movement getting it back into park. There is also seems like there is more than one neutral (between Park and Neutral)
I have bought a service kit and will check the pan for bits of metal, the oil is rather black too.
I am going to have a look at the cable and mechanism over the weekend and see what I can find!
Alena
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
