4l60e 1st to 2nd shift funny
Old Nov 7, 2012 | 01:41 AM
monsterjam5000's Avatar
i have a 1994 tahoe, i know this is not a tahoe forum but i am hope i can still get some help.
it has a 350 tbi and a 4l60e trans, the problem is that
When starting from a stop or nearly stopped position the transmission stays in the first gear and the engines revs up to nearly 4000+ RPM and shifts. I can get the trans to shift before that moment by pulling off the gas pedal while moving and the trans then shifts to the nexy gear and the cars then drives normally.
this only happens in first to second gear, any ideas what it could be?
Old Nov 8, 2012 | 05:38 AM
Re: 4l60e 1st to 2nd shift funny
anybody
Old Nov 8, 2012 | 06:21 AM
88 Z-ROC's Avatar
Car: 88 IROC-Z (L98)
Engine: Edel. Lwr, SLP Rnrs, Ported Plenum
Transmission: 700R, 2800 Stall
Axle/Gears: 3:42 Posi.(4th gen.) UMI R/Susp.
Try shifting it manually.. If you are able to shift manually then you may be lucky and it may just be the 1-2 shift solenoid.. I know this may sound a little unorthodox but check the fuses and also if your instrument cluster is functioning properly.. In my Tahoe the shift indicator wasn't showing and I replaced the fuse and the trans was cured.. lol
Good luck..
Old Nov 9, 2012 | 08:29 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
I bet the reverse drum is not flat and the second gear band is black burned or I've seen the 1-2 accumulator spring broken.
Old Nov 12, 2012 | 11:05 PM
its the band that locks 2 and 4 gear, so i have to 2 or 4th
Linson
Oct 24, 2025 02:00 PM
Lbibb
May 5, 2016 12:00 AM
racereese
Oct 3, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
