spider gear 26-28 spline question
Old Nov 21, 2012 | 09:18 PM
jh_shady01's Avatar
Car: 82 Z28
Engine: Vortec headed 350, lightly worked
Axle/Gears: LS style 7.5, torsen 3.42 disc
I know you can't run 28 spline spiders in a 26 spline carrier, but will a set of 26s fit in a 28 spline carrier? I'm too poor to upgrade axles at the moment. Both are open, nonposi carriers. Thanks.
Old Nov 21, 2012 | 10:19 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: spider gear 26-28 spline question
They should. The only difference is the size of the hole in the carrier that the axle goes through. 28 spline side gears will fit into a 26 spline carrier but the axles can't fit through the carrier hole. Putting 26 spline side gears in a 28 spline carrier will just mean the hole the axle goes through will have more room around it.
Old Nov 21, 2012 | 10:39 PM
jh_shady01's Avatar
Car: 82 Z28
That's my thought on it also. I just didn't know if the tighter housing added any strength value. Thanks for the quick reply.
Old Nov 22, 2012 | 12:16 AM
big gear head's Avatar
I'm not sure about that. I'm thinking that the 28 spline case is wider inside than the 26 spline case. It's been a few years, but I think I've tried that before and it didn't work.
hectre13
Dec 11, 2023 08:14 AM
draco
Oct 4, 2015 09:25 PM
hectre13
Aug 26, 2015 08:17 AM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
