need a 700r4 stall
Old Nov 26, 2012 | 12:10 AM
bears41666's Avatar
Car: 1991 camaro rs
Engine: 350 bored .030 over, 438rwhp 429tq
Transmission: 700r4 stage 3 race 700hp
Axle/Gears: stock axles and 3.23 gears
need a 700r4 stall
i have a built 350, big cam, 501 lift 297/301 duration,dart 215 heads current stall is stock. when i put it in gear it bogs down and will die. i want a 24-3500 stall, and has to be no more than 220 dollars prefer under 200, will be switchin to 4.10s or 4.56s later, any help is appreciated thanks
Old Nov 26, 2012 | 01:08 AM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
Re: need a 700r4 stall
cheap and converters don't go together.. and I'd be real impressed if you managed to even find a used 700R4 lockup converter for $200 if it's worth a crap.
Why did you dump all that money into the motor and not save for a converter? Surely you knew you would need one?
Old Nov 26, 2012 | 10:23 AM
bears41666's Avatar
Car: 1991 camaro rs
cuz im 19, this is my first build ever and ran out of money
Old Nov 26, 2012 | 04:23 PM
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
is this your DD? If it isn't, just sit on it and wait until you can afford a good converter.
Old Nov 26, 2012 | 04:35 PM
Killert's Avatar
Car: 88 Firebird.
Engine: 383 HSR
Axle/Gears: 9 Bolt, 3.27:1 Diskbrakes
I'd look into Yank convertors. Not cheap at all, but it will show you how much to save up for. I just bought a Yank SS3600 convertor.
Old Nov 26, 2012 | 08:33 PM
bears41666's Avatar
Car: 1991 camaro rs
not its not my dd, and never will be, i just want a fun street car. i was thinkin bout a b&m or a fti, wud those work if i was to ever go s/c or rear turbo setup?
Old Nov 26, 2012 | 08:53 PM
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
Haven't used FTI, but B&M are junk and their price reflects that. You won't get a GOOD converter for cheap. Period.
Old Nov 26, 2012 | 09:39 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Do NOT cheap out on a converter. That's the quickest way to eating a transmission. A high quality albeit expensive converter will save you money by lasting for years. Not months or even weeks as many fall victim to with the low budget converters.
Look at this:
http://ls1tech.com/forums/automatic-...education.html
Old Nov 26, 2012 | 11:12 PM
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
Look at this:
Was hoping to dig up that link again. There's a lot of great info in that thread.
Old Nov 28, 2012 | 08:16 AM
bears41666's Avatar
Car: 1991 camaro rs
well, do you guys think a 4k rpm stall will be too hi for a weekend warriorstreet strip use , i wont be using a lock up switch,
Old Nov 28, 2012 | 04:47 PM
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
No. There's a few of us on here that have converters in that stall range. I have a 4-4200, but I haven't used mine yet. Get it from someone who builds GOOD converters and you'll be just fine.
Old Nov 28, 2012 | 08:58 PM
Car: 1989 GTA
It will be a heck of a fun converter.
Circle D converters like the one in the link tend to have a firmer lockup than the other brands. (They don't use springs inside the converter that other companies use) Most people like this sensation.
Old Nov 30, 2012 | 05:01 PM
BADCAM70's Avatar
Car: 89 IrocZ
Engine: 5.7
Transmission: TH700
Axle/Gears: 2.77
I have used 3 B&M converters in my cars and have had luck with them even dumped a 150 shot of gas on 383sbc and that of the shelf 3000 stall B&M converter made it all summer and i whipped it badly.
Was i lucky maybe so,i have heard horror stories about them but as far as i have experienced they worked for me and in your situation with shortage of money i say buy a 3000 stall of shelf B&M it will wake your car up bigtime
Edit: This option is a quick fix to solve your boog problem and get some fun back in your car but these cheap converters are no more than astop gap solution.
Best regards Mats
HoosierinWA
Oct 7, 2015 10:15 AM
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
