POSI W/ Low gears?or stick with my non posi..?
Old Dec 3, 2012 | 10:27 AM
calgutie's Avatar
Car: 1984 Z28
Engine: 5.0 L (Carbed)
Transmission: 5-Speed
Axle/Gears: Lazy 2 check
Just curisous what would be best getting a 2.73 posi rear end or keepoing my non posi 3.23 gears??thanks!
Old Dec 3, 2012 | 10:44 AM
big gear head's Avatar
Re: POSI W/ Low gears?or stick with my non posi..?
Why not put a Eaton Posi or Yukon Dura Grip in the rear end that you have with the 3.23 gears? Or you could use one of the Power Trax lockers.
Old Dec 3, 2012 | 10:48 AM
calgutie's Avatar
Car: 1984 Z28
well the only reason is becuase i get get this rear end for about $200
Old Dec 3, 2012 | 11:04 AM
If it doesn't have the gears in it that you want then it's $200 wasted. That rear end should have the Auburn differential in it, and there is a very good chance that it's either worn out or very close to being worn out. You can't rebuild the Auburn. Put another $150 to $200 with that $200 and fix it the way you want it. Those gears are also going to through your speedometer off.
Old Dec 3, 2012 | 11:05 AM
calgutie's Avatar
Car: 1984 Z28
hmmm...you its probably better to just save up and get a 3.42 popsi rear end then?
Old Dec 3, 2012 | 12:20 PM
If 3.42 is what you really want then yea, you probably won't be happy with anything else. You sure won't be happy with a 2.73.
Old Dec 3, 2012 | 12:40 PM
calgutie's Avatar
Car: 1984 Z28
got you you think a 3.42 gears would be descent for my car...I got a 5 speed in it with a LG4 305 engine in it...Hooker 2055 headers 3" straight pipes witha flowmaster at then end, will be replacing stock manifold with a edelbrock performer intake soon...and this car is ym daily driver...
junior419
Apr 7, 2025 11:35 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
dbrochard
Jan 28, 2016 08:42 AM
loud91rs
Oct 5, 2015 10:05 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
