speedo quit working
Old Dec 20, 2012 | 09:17 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
speedo quit working
well this morning when i took my car to school my speedometer was working, got to school, parked the car till i got let out, but when i started to drive again my speedometer didnt work, i crawled under the car to make sure the cable is connected to the tail shaft and it is, what could cause this? i just did a motor swap but its been working for almost a month now till today. help? suggestions? how hard are the cables to replace?
Old Dec 20, 2012 | 09:33 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: speedo quit working
They're not bad.
Probably have to pull the gauges back to unclip the cable housing from the speedo.
The other end unthreads from the trans.
The mid section may be clamped down at the firewall or underneath.
Before assuming it's the cable, jack up the rear, put it on jackstands and unthread the cable from the trans. Spin the cable by hand and see if the speedo moves. Then, start the car and let it idle. Put it in D and let it roll. See if the speedo gear is spinning.
Since you just replaced the trans., it's suspect before the old cable / speedo that worked in the past.
Old Dec 21, 2012 | 07:08 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
https://www.thirdgen.org/forums/inte...eedo-woes.html
JamesC
92camaroJoe
Jul 29, 2023 07:57 PM
Jorlain
Aug 24, 2022 05:11 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Irocohio
Aug 12, 2015 08:03 AM
beachrodder
Aug 7, 2015 04:27 PM
