t56 speedo prob.
Old Jan 13, 2013 | 09:48 PM
grove's Avatar
Car: 1988 firebird
Engine: 305 tpi
Transmission: 95 T56
Axle/Gears: stock 10 built, yukon diff, 4.10
t56 speedo prob.
wired up the sgi-5c went for a drive and when my gps is reading 30, the speedo is reading 40 or a lil over. at 60, the speedo reads 80. tried to hit the down button on the sgi-5c while driving, didnt do anything. the way i have it wired up is: the purple wire coming from tranny sensor is going into sensor ground. yellow wire from sensor is goin into input. for the outputs, i have the purple wire from the vss buffer going into out3 and the yellow wire on the vss buffer going to
out4. there is no ecm either, i converted to a carb. Does anyone have any insight on how i could fix this?
Old Jan 13, 2013 | 10:47 PM
LilSki's Avatar
Car: 85 Trans Am
Engine: 98 Vortec 350 LT1 Cam w/ TPI
Axle/Gears: 9 bolt 3:27
Re: t56 speedo prob.
I had to play with the dip switches a bit on mine but one tip about the up and dn buttons is you much hold them and they adjust VERY SLOOOWLY. So you may think they are doing nothing but they are just slowly.
Old Jan 13, 2013 | 11:05 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Based on what you've posted, you haven't gone into all the options of adjustment in the manual.
http://www.dakotadigital.com/pdf/sgi-5c.pdf
The "application" used (described in the manual) is effectively a coarse adjustment of some outputs via the dip switch(es.) Your outs you're using sound fine though. The up/down have available a secondary coarse adjustment - RTFM for how to do that. Like said, the fine is slow. But you might need to change a dip switch. Depends.
Old Jan 14, 2013 | 02:09 PM
Jupiter's Avatar
Car: 82 Trans Am
Engine: 383
Axle/Gears: Built 4th gen 3.42 posi/disc
Heya grove. Nice combo you got there listed in your sig. VERY similar to my setup except i have the 2.02 aluminum trick flo but you have a tiny bit bigger cam. Everything else looks the same as what i am running 'my bottom end is all forged & 4 bolt main though'... VERY NICE!!!
Anyway so i am just now doing my t56 swap and using the same rear end gear as you. So being lazy to calcute and seeing this post i thought i would ask, What color gear are you using for the speedo sensor and, once you figure out the SGI-5c can you let me know what settings you used on the switches. Thanks!
Old Jan 14, 2013 | 04:26 PM
grove's Avatar
Car: 1988 firebird
Engine: 305 tpi
thanks jupiter. when i figure this thing out, ill post it. as far as the gear color. i didnt change out any gear in the trans. with the sgi box you shouldnt have to change out gears.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
meeklay812
Oct 1, 2015 03:46 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
Vincent135
Sep 28, 2015 10:50 PM
