700R4 speedo
Old Jan 15, 2013 | 04:24 PM
rkg8554's Avatar
Car: 87 Iroc Z 28
Engine: 355/ 600 Holly
Transmission: 700R4 shift kit & vette servo
Axle/Gears: 9 bolt 3;70s
700R4 speedo
I have gone thru about 8 page's of post and do not see my ? anywhere. What I want to know is, I am replaceing the trans (700R4) in my 87 Camaro. The trans I have now uses a cable driven speedo, the trans I am installing (700R4) has the electronic speedo. Can I swap out the speedo gears from my 87 trans to the 92 trans to keep my cable driven speedo or do I have to change my speedo and add the wire's for it.
Old Jan 15, 2013 | 04:25 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 700R4 speedo
Take the gears and housing out of your old transmission and put them in the new one.
Old Jan 15, 2013 | 05:11 PM
rkg8554's Avatar
Car: 87 Iroc Z 28
Re: 700R4 speedo
Thanks,Do you know if this require's any specialty tools.
Old Jan 15, 2013 | 06:37 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: 700R4 speedo
If your new trans. has a traditional spiral cut speedo gear (and not a straight cut reluctor ring) it takes:
1 bolt for the VSS
4 bolts for the tailhousing
1 clip for the speedo gear clip (if different than the new trans.)
Old Jan 17, 2013 | 04:47 AM
Pat Hall's Avatar
Re: 700R4 speedo
Actually, about 99% of the time, the gear on the output shaft of the trans is the same for both the electric and cable-driven speedos, so all you have to do is loosen up the one 10mm bolt that holds the electric sending unit in the tailshaft housing and just replace it with your cable-driven gear/housing. No need to remove the tailshaft housing at all.
Old Jan 17, 2013 | 07:30 AM
rkg8554's Avatar
Car: 87 Iroc Z 28
Re: 700R4 speedo
Thanks all, I will be pulling motor and trans today befor the artic air hits.
I will give this a try in the next couple days. THANKS AGAIN
loud91rs
Oct 5, 2015 10:05 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
