transmission swap?
Old Jan 25, 2013 | 12:47 PM
aesius191's Avatar
transmission swap?
i have a 86 T/A it has the L69 H.O. engine with a borg worner 5 speed trans and im thinking about swapping it for a 6 speed from a 92-99 vette anyone know how this would change my torque hp or overall performance? need some info before i spend money on something that wont work.
Old Jan 25, 2013 | 12:55 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: transmission swap?
Keep your T5 until you have a stronger engine.
The L69, 3.73 rear and T5 are very well matched with regard to gear ratios.
305 + 3.73 + Vette ZF or MM6 ratio T56 = poorly matched gear ratios.
Old Jan 26, 2013 | 01:38 PM
aesius191's Avatar
do you mean a bigger engine or more power? cause i have some work done and i have dyno tested it a 320 hp and almost 350 torque. im wanting to get more mid and top end i feel like in 4th and 5th it loses all its pull
Old Jan 26, 2013 | 04:20 PM
jmd's Avatar
jmd
If you're losing pull in higher gears, you may want to check into fuel delivery to make sure that's not an issue.
A 320hp 305 is going to make power at a higher rpm range than a stock one. Bottom line is what I stated twice in the first post.
When you get into a 350 or bigger, then consider the 2.6 first gear / .50 sixth gear stuff.
AussiePr0nCar
Mar 6, 2020 04:04 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
gta90
Sep 15, 2015 04:00 PM
E Rod
Aug 28, 2015 05:17 AM
mizz0313
Aug 12, 2015 06:45 AM
