9 bolt posi shims?
Old Feb 4, 2013 | 11:11 AM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
9 bolt posi shims?
I have a 9 bolt rear in my car with less then 1000 miles on it. It has new friction cones as well as all other new parts. It is not posi half the time and fails the posi minimal break away test of 35 ft.lbs. I know I have to shim the friction cones. Does anyone know where I can find friction cone shims for a 9 bolt?
Old Feb 4, 2013 | 11:31 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
Re: 9 bolt posi shims?
I got mine from Ed Miller right here on this site.
I think he goes by ebmiller.
Old Feb 4, 2013 | 12:55 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Few places sell them.
Covered in this thread.
https://www.thirdgen.org/forums/faq-...now-about.html
Old Feb 4, 2013 | 03:00 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
I got from Ratech part 1104.
Old Feb 4, 2013 | 03:03 PM
Car: 89 Formula 350
are those for shimming the pinion or friction cones??
Old Mar 1, 2013 | 12:12 PM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
http://www.ratechmfg.com/gmstandard.htm
1104 is
ID. 1.450
OD. 2.250
thickness range .020-.050
You need
DIMENSIONS FOR SHIMS:
Max Outside Diameter=2.5"
Min Inside diameter= 1.5
according to this article
https://www.thirdgen.org/9boltservice
Old Mar 1, 2013 | 04:11 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Both. The pinion shims were the closest I could find to use on the cones.
F-body driver
Mar 6, 2023 11:44 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
djmarch
Sep 13, 2015 01:35 PM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
