4th gen rear-ends
Old Feb 25, 2013 | 12:05 PM
kitt462d's Avatar
Car: 1985 TA
Engine: 350 Carb
4th gen rear-ends
Is there any difference between 4th gen V6 and V8 rearends?
Old Feb 25, 2013 | 12:09 PM
big gear head's Avatar
Re: 4th gen rear-ends
They are all 7 5/8 rear ends with 28 spline axles. The '93 to '97 limited slip differential was the Auburn and the '98 to '02 was the Torsen.
Old Feb 25, 2013 | 02:34 PM
MustangEater82's Avatar
v6s were all open diffs, unless it was a semi rare y87 package, then the door code will be G80
Old Feb 25, 2013 | 08:45 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Same with third gen diffs. The diff itself is identical between V6, V8 etc. The only difference between them all was the gearing and if it was open, gov loc or posi. Strength wise, they're all the same.
A fourth gen diff with it's 28 spline axles is just as strong as a 90-92 third gen because they also had 28 spline axles. You can upgrade 82-89 10 bolts to 28 spline as long as you're using the proper carrier (posi)
The only advantage to upgrading to a fourth gen diff is to get and use a newer disk brake system.
my86bird
Oct 23, 2015 12:20 PM
New2Chevy
Sep 28, 2015 12:35 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
cam-mike
Aug 24, 2015 07:23 AM
