Opinions wanted: 2 Series 9bolt carrier and cone condition (pics)
Old Mar 11, 2013 | 08:04 PM
Keoman's Avatar
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
So a while back i made the mistake of letting my cones wear out to the point that it completely screwed up the spider gears. Chipped teeth, rounded teeth, bad news. I have learned quite a bit since that day.
Question I have is, is this carrier salvageable? Can the cone that still has a little meat on it be milled or time to throw them away?
I have access to a mill and lathe for a limited time and just need to know if I should bother with them or not.
I have read the 9Bolt cone repair howto. I was looking for an opinion from someone who might have done this before.
Side #1
Side #2
Old Mar 11, 2013 | 08:17 PM
Twin_Turbo's Avatar
Re: Opinions wanted: 2 Series 9bolt carrier and cone condition (pics)
those are junk. New cones are in order and you will have to have the case halves machined for them since they do not have the recess that the stockers have, remove the raised portion in the carrier and it'll be fine.
I have machined a couple of these cones and shimmed them, I would not take them down a lot more than this:
Yours are worn down a lot deeper than the as cast section near the outer diameter, mine are a little higher still in the machined area
that's an added benefit to the replacement ones, a lot more spline contact area but like I said, need to machine case halves
Old Mar 11, 2013 | 09:35 PM
Keoman's Avatar
Thanks Twin_Turbo!
Looks like ill be ordering new cones when needed. I will machine the case halves to accommodate for the new cones.
Question. Does the cone also need to be taken down a bit so it doesn't contact the case bottom (part you can see in the window?)
So I am kind of seeing this is just a poor design correct? The cones eat at the case half until eventually you run out of material and the whole unit becomes a giant door stop?
hectre13
Dec 11, 2023 08:14 AM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
hectre13
Aug 26, 2015 08:17 AM
Navy8125
Aug 25, 2015 08:25 PM
knight72
Aug 10, 2015 09:32 PM
