REAREND REBUILD POSSIBLE - RECOMMENDATIONS
Got an 88 GTA; LB9; Look at slow speeds of 0 to 5 mph I'm hearing a clunking noise from the rear of the car. However, once I'm up to speed, the noise disappears. It's my opinion that maybe it's time to rebuild my rearend. Therefore, I'm looking for suggestions on what to do. Or, has anyone else experienced this? If so, what was your solution?
Thanks,
Jeff
Thanks,
Jeff
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: REAREND REBUILD POSSIBLE - RECOMMENDATIONS
Unless you have some experience or know someone who does I would bring it to a shop
https://www.thirdgen.org/forums/tran...axle-gear.html
Read this and see if you are up to it.
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
I just rebuilt a 9-bolt for the first time. It's not difficult but time consuming and involved a lot of reading before doing.
3.8TransAM
Sep 27, 2015 08:37 PM
