700r4 knocking need help
Old Apr 12, 2013 | 11:14 AM
Bigben93's Avatar
Car: 1984 Pontiac T/A
Engine: 69 lm1 shortblock 70 lt1 heads
Transmission: cahall performance pro race-700r4
Axle/Gears: 3.42:1 auburn posi
Hey guys whats going on. i got a 84 pontiac T/A with a 355 in it bolted up to a 700r. I just had my transmission rebuilt steels clutches bands bushings and seals.I put it all back together and it starts knocking. coming from the front pump, torque converter area. Now when i move the tv cable in or out the knocking either goes away or comes back, any idea on what the problem is? i d apreciate the help
Old Apr 12, 2013 | 11:51 AM
Yenipenny's Avatar
Car: 92 RS Heritage
Re: 700r4 knocking need help
One possible cause is that the torque converter bolts are loose.
Old Apr 12, 2013 | 12:44 PM
Joe Tag's Avatar
Definite possibliity. I bought a parts car years ago, started it up and it sounded like a main bearing was shot. Went to pull the trans and the torque converter bolts were finger tight.
Old Apr 17, 2013 | 01:23 PM
Bigben93's Avatar
Nope, its not the converter bolts. ive double checked to make sure that they are tight, and that also wouldnt explain the noise going away when i increase or decrease line pressure.
Old Apr 17, 2013 | 01:24 PM
Bigben93's Avatar
Old Apr 18, 2013 | 02:06 PM
ImBrandon's Avatar
Car: 1991 Pontiac Trans Am
Axle/Gears: 3:42
Could be a long list of things. Convertor wasn't installed correctly, The input shaft has play going in and out. Did you check your trans before installing it? I'm no expert so if I'm wrong correct me or clarify what you think I meant to say.
Old May 2, 2013 | 09:43 AM
ImBrandon's Avatar
Axle/Gears: 3:42
Figure out the problem yet?
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
92projectcamaro
Sep 29, 2015 07:07 PM
efiguy
Sep 27, 2015 01:30 PM
6998poncho
Sep 25, 2015 02:56 PM
