700r4 question........need advise
Old May 3, 2013 | 04:33 PM
richw40's Avatar
Car: Silverado 1986 TransAm
Hi all, I was told this is an early 700r4, I don't know the yr, it sits in a 1986 Trans am. I had both rear wheels off the ground to install tires, and I noticed that when I spun the wheels in any direction, while the trans was in park, the driveshaft didn't move. When I spun them in a forward direction, the opposite wheel went the other way. Shouldn't the trans in park lock up the rear wheels.??
I don't understand why the rear wheels could move and not the drive shaft??
I do lot drive the car right now, works in reverse and forward.
Sorry for the dumb question but I did search the boards for these questions.
thanks for any guidance, Rich
Old May 3, 2013 | 04:44 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: 700r4 question........need advise
Perfectly normal for an open differential. When you take the cover off to change the rear diff oil, observe how the spider gears work with the ring gear and you'll see how/why it works that way pretty quickly.
Old May 3, 2013 | 05:13 PM
richw40's Avatar
thanks for that info............that scared the hell out of me.......whew !
Old May 3, 2013 | 11:09 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
http://en.wikipedia.org/wiki/Differe...ical_device%29
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
