Help!!!
Old May 13, 2013 | 08:59 PM
87hellbird's Avatar
Car: 1987 formula
Engine: 305 tpi
Transmission: t5
Axle/Gears: 3.45
Help!!!
I had an engine fire, and it burned a hole in the hose thats in between the clutch pedal and the slave cylinder, I was wondering what it is called if
i went to the auto parts store and how do you get it off? Do you have to take the brake stuff on the firewall off? Or how do you get to it. My engine bay is very stripped down with no emitions stuff. I have a t-5 tranny and I figured that I would put it in here for the people who has done a t-56 swap cause they probably know.
Old May 14, 2013 | 02:05 AM
Pat Hall's Avatar
Re: Help!!!
It's a little spendy for a plastic line, but I found a new one on Ebay. http://www.ebay.com/itm/TPI-T5-Camaro-Firebird-Hydraulic-Linkage-Master-to-Slave-Clutch-Hose-Line-/130901790599?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ACamaro&hash=item1e7a5acf87&vxp=mtr To remove the old one, there's a little roll pin in the end of the master cylinder and the slave cylinder you have to knock out with a small punch. Don't have to remove anything from the firewall or trans, just knock out the roll pins, pull out the old line pieces, put in the new line and re-install the roll pins.
