timken axl seal HELP
I just had my whole rear end rebuilt. Had motive 3.70 gears, raetech master overhaul kit, and timken set 9 bearings and seals. The guy I had Install everything was doing rear ends for years and by the look of his shop with over 500 rear ends leads me to believe he knows his stuff. I assured him I had all the right parts. I referenced the 9 bolt sticky post for the bearings and axl seals. Problem is.......I remember what the new seals looked like and saw the old ones pulled and they looked nothing alike. Actually the 2 old ones were identical. He was a little worried about it leaking and told me after its installed if it leaked bring it back. I would hate to have to put it All back In just to drive it 10 miles to pull it out again. I remember one new backing was black plastic and the other was metal and I believe green. Anybody install these timken ones that I am describing? Are they wrong?
Car: `86 SS / `87 SS
Re: timken axl seal HELP
Post pictures.
Post part numbers.
Odds are much better for help that way.
Post part numbers.
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
Mine look the same. They are different seals and part numbers. You should be ok as long as you have the right seal on the right axle.
Car: 1988 IROC-Z camaro
Engine: 355 TPI
Transmission: tko 500
Axle/Gears: Dana 44 3.31 posi pbr brakes
Timken has something wrong with their part numbers for those seals and has for a long long time for the 9 bolt. I saw your title and knew it was in reference to these seals. Whats worse is that the one seal that was correct in that kit started leaking after only a few months for me.
Anyways the correct seals for a 9 bolt can be bought from Napa. They are part numbers
Nos 16491 (left)
http://www.napaonline.com/Catalog/Ca...491_0070160042
NOS 16542 (right)
http://www.napaonline.com/Catalog/Ca...542_0070160044
Note: It is important to use the correct seal on the correct side. Switching them up and you will most likely have leaks from the direction of the slashes inside the seal to direct fluid back into the rear. Also...ive had these seals in my rear end for about a year or so now and no leaks.
Nos 16491 (left)
NOS 16542 (right)
Car: 1989 IROC & ROLL-Z
Engine: L98 Vortec FIRST TPI
Transmission: T56, Mech Speedo
Axle/Gears: G92 J65 3.27
Putting the seals in backwards will cause leaks. The information underneath is correct.
If you want to buy the RH timken seal from autozone, the part number is 710179
Nos 16491 (left)
NOS 16542 (right)
Nos 16491 (left)
NOS 16542 (right)
1Aauto
Sponsored Vendors
Oct 13, 2015 03:06 PM
