Broken Carrier question
Car: 87 T/A
Engine: 400SBC Carb'd
Transmission: T56, Kevlar clutch
Axle/Gears: 3.73 Yukon Duragrip posi
So, my rear end blew apart on the freeway (
), and my gears and bearings need replaced (duh), but here's my problem.
The carrier itself took some nasty hits, and I think I need to replace it (it's really messed up where the pinion shaft lock bolt goes...).
Can I just get a carrier "case" like this: http://www.summitracing.com/parts/yg...model/firebird
without having to replace the internals?
I really don't want to spend $400 on a new posi, when mine is perfectly fine, except for the banged up carrier case.
And if I CAN stuff my internals into a new case, how hard is it? Do I need special tools?
Thanks guys.
), and my gears and bearings need replaced (duh), but here's my problem.The carrier itself took some nasty hits, and I think I need to replace it (it's really messed up where the pinion shaft lock bolt goes...).
Thanks guys.
Re: Broken Carrier question
Those cases are for a standard differential, not a posi. You can not put posi parts in a standard case. If you have a standard differential then just go to a junk yard and get another one for about $20. If you were close I would let you have one for about $5.
If you have an Auburn then you would be doing yourself a favor by replacing it with a new Eaton Posi or Yukon Dura Grip.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I just had to tosss a 4th Gen Auburn carrier because of an elongated shaft lock hole.
If you ever tried to install a spring pack into an Auburn carrier - you'd understand !!
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
knight72
Aug 10, 2015 09:32 PM
