New clutch. will not go into gear
Old Jun 5, 2013 | 04:47 PM
Irocz2nyG's Avatar
(Borg Warner T-5)
So, I just put a new clutch, bronze pilot bushing and new pressure plate and a resurfaced fly wheel in my camaro. And some how it wont let me go into gear, to the point where i think the clutch isnt fully disengaging,,, but i can get in any gear when the car is off. I checked my specs on how far the slave cylinder rod is supposed to travel and i was good with that (over .513). I also was watching to see if the throw out bearing was on. and i checked that from the boot.. Trully, its making no sense to why it wouldnt work. clutch was faced the right way. I dont know what trully to look for now.....I dont feel like blaming the hydraulics because (if it worked on the old clutch than why wouldent it work on a new clutch). If any body has any suggestions. please do free to give me an answer to what i may have done wrong. thank you.
Ps.) If pictures would help. let me know and al post
Old Jun 5, 2013 | 06:05 PM
Re: New clutch. will not go into gear
Old Jun 5, 2013 | 07:20 PM
Banks4004's Avatar
Car: 1990 Camaro
Engine: 5.0
Transmission: T5 WC
Was the clutch before your new one the OEM clutch?
Old Jun 6, 2013 | 07:57 PM
Irocz2nyG's Avatar
Nope that isnt my problem. i have that on correct. and its facing the right way.. do u have anyother suggestions
Old Jun 6, 2013 | 07:58 PM
Irocz2nyG's Avatar
yeah the old one was stock. GM
Old Jun 6, 2013 | 09:59 PM
Banks4004's Avatar
Car: 1990 Camaro
Engine: 5.0
Transmission: T5 WC
Well I had a similar problem and I've heard similar from others switching from stock, and sometimes different clutches want a bit more travel that the current setup allows. Not sure if it only applies to aftermarket clutches or not. But I took advise from one thread on here to make a longer actuator rod for the slave cylinder and it fixed it perfectly. Added 1/8 inch
Old Jun 7, 2013 | 03:21 PM
Irocz2nyG's Avatar
yeah i feel you on that one. but this one was a stock replacement from centerforce. its kind of upsetting if i have to put a longer rod.. These hydraulic systems should be able to adjust to a new clutch. (not that it isnt pushing over a half inch). An personally, i swear i did what i did right. i put a new pilot bushing in, and i didnt mushrroom the i.d. of it. new throw out bearing (facing the correct way, larger diameter towards engine,smaller towards transmission). clutch disk facing the fly wheel on the right side. This **** is not making sense to why it wont work.
Old Jun 7, 2013 | 05:16 PM
Banks4004's Avatar
Car: 1990 Camaro
Engine: 5.0
Transmission: T5 WC
There is a thread I cant find with identical problems to yours with that rod extension solution... anyway,the person in that thread had a centerforce I believe and so do I and it seems they just need a little extra movement
Old Jun 7, 2013 | 05:42 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
One way to fix it, is to put shims under the pressure plate to flywheel (all 6 bolts).
About .010-.015 will do it.
When it wears a little you can remove them.
Some times the marcel is too thick in the disc.
that makes it over .335 thick causing that problem.
So if you have everything else right, try that.
Old Jun 7, 2013 | 08:29 PM
Irocz2nyG's Avatar
Thats not a bad idea. I'm going to try that..
Old Jun 7, 2013 | 08:31 PM
Irocz2nyG's Avatar
yeah your probably right about that. I bet if i used a pry bar on it. and tryed to go further it would disengage.
Old Jun 7, 2013 | 08:38 PM
Irocz2nyG's Avatar
pry bar on the clutch fork *
Old Jun 7, 2013 | 09:51 PM
Irocz2nyG's Avatar
http://s1297.photobucket.com/user/Ir...?sort=3&page=1
Pictures that i have took. on this assembly..
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
georgiaslim45
Sep 9, 2015 08:11 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
tonys91rs
Sep 2, 2015 07:07 PM
