HELP 1984 TA rear end
Old Jun 20, 2013 | 01:01 PM
kleist's Avatar
Car: 1984 t/a
Engine: rebuilt 327
Transmission: stock
I have a 1984 TA that is a standard and had 5 liter HO engine. When that engine died I had a rebuilt 327 installed.
I was looking to get the gears more compatible for the new enginge, but I do not know if I have Posi traction ?
is there a website or anyway to check this without pulling the cover ?
Old Jun 20, 2013 | 04:26 PM
big gear head's Avatar
Re: HELP 1984 TA rear end
Did you read the "FAQ about 10 bolts" sticky?
Old Jun 20, 2013 | 05:59 PM
If it was REALLY a stick/HO car, it should have come with 3.73s.
Sure... just pull the cover. Not sure what's the big deal about that, seems like every n00b feels obligated to display their n00bness by saying that though. All it does is advertise that you're a n00b.
Go change the fluid, which OBVIOUSLY needs doing anyway, and look at the parts while you're doing it.
Old Jun 25, 2013 | 05:06 PM
Cosmik Debris's Avatar
The posi rear on the HO has a metal tag under one of the cover bolts.
Old Jun 25, 2013 | 08:35 PM
anthony64ss's Avatar
Car: 1984 Z28
Engine: L31
Transmission: WC T5
Axle/Gears: 10 bolt 3.73
which is most likely long gone.
like sofa said, pull the cover. Only 100% way to know what diff.
I thought I read there was some kind of issue getting a posi factory on an 84 car. Maybe that was 83?
My 84 HO is 3.73 open.
Old Jun 26, 2013 | 08:58 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Same open 3.73 L69 84 bird.
3.73 should be fun with a 327
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
