fixed my 700-r4
Old Jul 12, 2013 | 04:48 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
fixed my 700-r4
so i replaced my valve body with a rebuilt unit,i replaced the TV cable with a factory correct part. i replaced the govenor assy.and the servo assy AND NOW.....it shifts normally,the car drives as it should.and im one happy boy,indeed
Old Jul 16, 2013 | 08:27 PM
Car: 86 IROC
Engine: 5.0 TPI
Re: fixed my 700-r4
well. as luck would have it put 50 miles on it in 4 days and now back to super high shift points.same as before. what a waste of $330
Old Jul 16, 2013 | 08:42 PM
morgsie's Avatar
Re: fixed my 700-r4
It's possible theres so much debris in the oil (clutch/band material, metal, etc.) that it is interfering with the shift valves in the valve body. A spec of dirt can cause them to not work well or at all. Is the governor matched to the valve body?
Old Jul 17, 2013 | 03:10 PM
Car: 86 IROC
Engine: 5.0 TPI
Re: fixed my 700-r4
im beginning to think the 700 r 4 is a weak and badly designed transmission. I have began looking around here and elsewhere.and im finding WAY too many GM vehicles that are otherwise fine cars EXCEPT they had a bad trans and got it rebuilt, they HAVE a bad trans that needs rebuilt,or they have a trans that WILL need to be rebuilt sooner than later. you guessed it , they have 700-r-4s or its evil twin , a 4l60-e. I would rather keep my car all original, as its a nice rust free car.but hell a manual trans of ANY kind would beat this ****, hands down. and really ,my only comfort is its NOT a ford!!
Old Jul 17, 2013 | 10:24 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: fixed my 700-r4
The early ones usually went south around 60k miles. The '87 and later ones are a bit better.
In stock form it's not a transmission that will take a lot of abuse (like treating it like a manual). I also feel that these things die from neglect, mis-adjusted TV cable and a general mis-understanding of how this transmission is designed to work (poor rebuilding practice).
I have 86k no-abuse miles on the one in the IROC. I have a 4L60E with 130k in my GMC Safari that's still going (it's always had a funky 1-2 shift, though).
Bubbajones_ya
Oct 25, 2015 08:01 PM
Reid Fleming
Oct 10, 2015 09:56 PM
dusterbd
Sep 29, 2015 08:40 AM
z28joe2
Sep 28, 2015 05:54 PM
mfp189
Sep 27, 2015 09:25 AM
