LAKEWOOD BLOW PROOF BELL HOUSING
Car: 1987 z28 all stock + tricked 85 z28
Engine: 388 stroker + Procharger D1SC
Transmission: TKO 600
Axle/Gears: richmond 3:73, EATON, moser shafts
my lakewood blowproof bell housing interferes with my right exhaust header flange rite where the starter is is it ok to cut the bell housing ? the amount i need to remove is quite a bit
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: LAKEWOOD BLOW PROOF BELL HOUSING
It will void the sfi cert and create a weak spot on that side of the bellhousing, but still quite a bit safer than a stock bellhousing during a clutch/flywheel failure
What headers?
What headers?
Thirdgen89GTA
Nov 26, 2015 11:04 PM
