T-5 starting issue
Old Aug 8, 2013 | 10:48 AM
DiabolicalRS's Avatar
Car: '90 Camaro
Engine: 305 tbi
Axle/Gears: 9 bolt posi 373
T-5 starting issue
just wanting to know what the sensor was for when the clutch pedal is pushed in to start the car, also where is it located, and where can i find this piece at?
Im goin to go through my starter and the wires to it and redo them and make sure they are no to blame. thanks
Old Aug 8, 2013 | 06:00 PM
Re: T-5 starting issue
It's not a "sensor", just a switch.
It's on the clutch pedal.
It performs the EXACT SAME function as the neutral safety sw on an auto car does: prevents you from starting the car in gear. Imagine if you will, a car with a remote start, and that switch bypassed.
Wires are yellow and purple. I STRONGLY advise against "redo"ing ANY wires; especially ones like that, that NEVER go bad unless sodomized. Instead, just look at em and make sure they're hooked up right. You could even make yourself a little jumper with a short piece of wire to plug the car harness onto instead of the switch, if you think the switch is defective.
If you think you've got wiring and electric problems now, JUST WAIT until you get in there and randomly hack on some stuff without understanding what it does or why it's there or what it's for, as would clearly appear to be the case... that's about the best way I can think of to end up sitting by the side of the road with your significant other riding off in disgust in your worst enemy's import.
Old Aug 9, 2013 | 10:14 PM
Car: '90 Camaro
Engine: 305 tbi
ok then i want to say when i had to put my new pedals in i replaced that switch then, but ill just look at it first, i will start with one of my starter wires and make it longer cause i think thats my problem then after reading your post
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
86Base
Aug 8, 2015 01:34 PM
