4L80 Pan On 700R4
Old Sep 4, 2013 | 10:05 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Axle/Gears: Borg Warner/ 2.77
4L80 Pan On 700R4
Hello
I have a left over pan from a 4L80 and looking at how the one off my 700R4 is pretty beat it, can i swap it out with no issues, or will I run into problems? Please let me know before I begin to reinstall everything. Thanks!
Old Sep 5, 2013 | 01:26 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 4L80 Pan On 700R4
See a problem?
#6 is a T700 /4L60 pan .
#7 is a 4L80 pan
Old Sep 5, 2013 | 06:39 AM
http://www.bulkpart.com/Merchant2/me...General-Motors
Whaddya think? (probably not too different from Oz' link)
Old Sep 5, 2013 | 07:54 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Unless it is a misprint and you mean 4L60?
Which is the same trans as the T700 renamed
Old Sep 6, 2013 | 01:07 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
4L80e? nope.. not a chance..
some 4X4 trucks with the 4l60E had a deeper pan that bolts on and should be cheap from any junkyard, but you need to get the proper filter to go with it..
Old Oct 4, 2013 | 03:35 PM
Arts89Iroc's Avatar
Car: Camaro
Engine: 5.7 TPI
Then it is probably off of a 4L60, cause i put the 700R4 gasket on te 4l60/4l80 pan and it matched! its just the pan i want to put is a bit deeper
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
