speedo cable help!
Old Sep 6, 2013 | 03:55 PM
MeanFbirdT/A's Avatar
Car: 1984 Pontiac Firebird S/E
Engine: LG4 305
Transmission: Borg-Warner T5
speedo cable help!
Hey everyone. I had a couple of questions concerning my speedo cable. I have a BW T-5 and a stock 3.42 open diff. First question, when I go to remove the cable from the trans to check if its broken, will tranny fluid spill from the hole? Next question, whats the best way to remove it and test its function? Thank you.
Old Sep 6, 2013 | 05:12 PM
ItalianIroc-Z's Avatar
Re: speedo cable help!
ok to remove it you shouldnt get more that a couple of drops of oil ... than to check the cable ... put and electric drill to the tranny end on the cable spin it and see if you gauge goes up or not
Old Sep 7, 2013 | 06:54 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
https://www.thirdgen.org/forums/inte...eedo-woes.html
JamesC
Old Sep 8, 2013 | 10:37 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
FYI: If you have the stock two part cable you should replace it. I strongly recommend to all my T56 speedo drive conversion customers that it be replaced. They seize and tear up the drive gears. And you have to remove the trans to replace them. Happened to me and two of my customers before I started recommend it be replaced.
The cable is cheap, $10 at Orielly's or Auto Zone. Part number CA-3001
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
