T5- Grinding when coasting to a stop
Old Sep 8, 2013 | 02:58 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Transmission: T5 Manual
This problem seems to keep coming back. Been through a few new thrust bearings and it goes away for a while.
It's a rebuilt T5 with aftermarket gears and G Force case. Shifts really smooth, no problems anywhere except:
Occasionally when you slow down and put it in neutral or hold the clutch in it makes a grinding noise you can feel through the car. Only happens once in a while sometime just ticking over in gear it will do the same thig.
Driving me insane- any suggestions?
Many thanks.
Old Sep 15, 2013 | 05:06 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Re: T5- Grinding when coasting to a stop
Need some advice on this please someone. It's not terminal grinding yet but seems to be getting worse.
Old Sep 15, 2013 | 11:40 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Gearset issues wouldn't tend to be fleeting as you've described.
Throwout bearing is what it sounds like.
If you push the clutch in, pull out of 4th and into neutral and it does it;
But you leave the clutch pedal be, pull out of 4th and it doesn't do it,
Then I'd consider the TOB a suspect of the noise.
Old Sep 16, 2013 | 02:18 PM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Hey jmd- many thanks for responding with sound advice. So pop it out of 4th and coast without clutch and see if it does it?
Thanks a million
Old Sep 10, 2014 | 07:40 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
New beefier TOB and 200 miles later the sound is back. This time I used the self aligning bearing. Was perfect but now the sound is back.
Could it be related to alternator/ PS pump/ Flywheel or starter re-engaging?
Old Sep 11, 2014 | 02:22 PM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Right managed to capture it making the noise. I really need help with this.
Old Sep 12, 2014 | 08:00 AM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Need help guys. Mechanic not helping me at all.
Old Sep 13, 2014 | 04:07 PM
ZZ42Fast's Avatar
Car: 1988 IROC Vert
Engine: 355 ZZ4
Yesterday the clutch pedal went to the floor.. Couldn't select gears. Pumped it a few times and it came good.
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
racereese
Oct 3, 2015 03:46 PM
sjorgens
Oct 1, 2015 07:54 PM
Luigytico09
Oct 1, 2015 08:46 AM
1HotZ28&SS
Sep 28, 2015 08:58 PM
