700r4 not shifting
Old Oct 9, 2013 | 06:22 PM
Race-Dave's Avatar
Car: 91RS
Axle/Gears: 373 4th gen
700r4 not shifting
How's everybody doing this evening? I have a 91 camaro, 350 engine, I just installed a new dif. with 3:73 gears, I had 2:73. Since changing the rear end my trans. won't shift at WOT. It does have a shift kit I installed several years ago. Under normal driving it shifts OK. I searched alot of threads on here and alot of people had this problem, but I didn't read about a fix. I have not pulled my governor to check it.I see where Summit has a Gov. recalibration kit, I would like to know if anyone has used it with good results.Thank You
Old Oct 9, 2013 | 09:34 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 700r4 not shifting
Originally Posted by Race-Dave
won't shift at WOT.
Into what gear?
Will it shift if you do it manually ? A quality shift kit should allow manual shifts
Old Oct 10, 2013 | 04:01 AM
Race-Dave's Avatar
Car: 91RS
I haven't tried to manually shift it, It's a B&M transgo kit. It won't shift from 2nd to 3rd. When I get off work tonight I will find a strech of road and check other shifts
Old Oct 10, 2013 | 05:55 PM
Race-Dave's Avatar
Car: 91RS
Ok went out and flogged my car tonight, it will shift from 1st to 2nd at about 4500 rpm, but not from 2nd to 3rd, l let it run up to 5500rpm. Also it wont 't manually shift into 3rd at WOT. if you let off the gas a little it will shift into 3rd. I didn't notice this problem until I installed the new rear gear.
Old Oct 10, 2013 | 08:04 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Is the TV cable that controls the shifts adjusted correctly?
Old Oct 11, 2013 | 04:07 AM
Race-Dave's Avatar
Car: 91RS
Yes. whem I installed my shift kit there was instructions on how to set the TV cable according to Trans pressure. I have since lost these instructions, so now it is set by the normal method
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
