How to tell when converter lockup happens
Old Oct 11, 2013 | 05:01 PM
RavageTheRoad's Avatar
Car: 1991 RS
Engine: L69?
I have always wondered if mine was operating properly, and now that I have my car going into closed loop, I'm thinking it isn't. I'm only getting about 15-16 mpg, almost all highway driving. What happens when it locks up? Does it behave almost like a manual in gear i.e let off gas, it will engine break, give it gas, car speeds up before RPM? I get that in 2nd and 3rd, but when I put the car in OD, I dont get that feeling on the highway. If I do find out it isnt working, would a switch be a viable option, and what is the easiest way to run one?
Old Oct 11, 2013 | 06:29 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: How to tell when converter lockup happens
Revs should drop 2-300 rpm when lockup engages and rise the same when you touch the brake pedal to unlock
Old Oct 11, 2013 | 08:34 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Lock up feels a lot more direct at highway speeds. It's just like driving a manual transmission. There is zero mush between accelerating faster and the RPM's rising. With the converter unlocked, there is a small bit of mush (extra RPM rise) and it's easier to accelerate.
Stock lockup occurs at 25 mph or 40 mph depending on model. L98's for example lock at 40 mph. When it switches to lockup mode, it will feel like about 1/2 a gear difference.
Old Oct 12, 2013 | 12:36 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
It's been a while since I was aware of the TCC locking and unlocking.
Try this No. 1:
1. Put the trans in manual 2nd and accelerate from a full stop.
2. You'll feel it shift = 2nd gear
3. You'll then feel another "light bump" = indicates TCC lockup with a slight drop in RPM
Try this No. 2:
1. Drive the car in OD or D at a steady +65MPH
2. Take foot off gas pedal and coast for a sec - note RPM's
3. Tap brake pedal. The TCC should unlock and the PRM's should drop.
Old Oct 13, 2013 | 04:53 AM
Car: 1991 RS
Engine: L69?
Thanks for the replies, guys. Looks like I have another circuit to repair. Do the solenoids really go bad or is it usually a wiring issue? I feel like it may be hunting when in 2nd. If I keep a steady pressure on the throttle at around 35-40 if feels like it eithre continuously locks and unlocks or just surges slightly/hunts. In D or OD i get not RPM change on the highway after doing what was suggested above.
Edit: Just for reference, I do have an aftermarket tach hooked up because mine has the resistor problem and is constantly pegged completely around the gauge, so I should be getting pretty accurate RPM readings.
loud91rs
Camaros Wanted
Mar 28, 2016 04:13 PM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
bjpotter
Oct 4, 2015 07:48 PM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
