T56 LT1 to LS1 Midplate Shims Bearings Measure?
Old Oct 30, 2013 | 11:50 AM
scottwrightF1's Avatar
Car: 1988 Camaro Iroc / 1989 Firebird TA
Engine: Camaro 350 cid / Firebird 305 cid
Transmission: Soon T56 D&D Viper (WC T5) / WC T5
Axle/Gears: 9 bolts; 3.45>3.89 / 10 bolts; 3.08
Hello,
I am doing a midplate sway from LT1 to LS1 midplate. I was wonding if there is any tips on how to remove the bearing and shim from the Lt1 without having to go to the mechanic shop to do it? I am going to reuse the shims and bearings again because it never be used. Should I heat the aluminum midplate and what do I pull the bearing out with? I dont want to mess it up.
I am bit confused how to measure the midplate to get the right amount of shims for the new LS1 midplate. I cannot find any sort of information how to measure the midplate clearance without seeing a picture or instruction.
Please let me know.
Thanks.
Old Oct 30, 2013 | 12:12 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Re: T56 LT1 to LS1 Midplate Shims Bearings Measure?
Try D and D transmissions they can help I bet
Old Nov 2, 2013 | 01:44 PM
Thanks for the information. That where my trans came from D&D. I will try them.
Anyone know?
dbrochard
Sep 19, 2015 08:13 PM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
L0tuS
Sep 4, 2015 11:16 PM
tonys91rs
Sep 2, 2015 07:07 PM
