Prothane Transmission Mount
Old Nov 21, 2013 | 08:11 PM
charliemccraney's Avatar
Car: 1988 Firebird Formula
Engine: 305 (LO3)
Transmission: 5 spd manual
I have the 7-1604 mount. The stud does not fit through the crossmember. It is 7/16 and the old mount is 10mm (just over 1/32" smaller). Is this normal and I just need to open up the slot in the crossmember a bit?
Old Nov 21, 2013 | 10:21 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Re: Prothane Transmission Mount
Its normal. Just file the hole open alittle and you'll be fine.
Old Nov 22, 2013 | 06:50 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Some members experience vibration issues with poly. You might take note of the following:
https://www.thirdgen.org/forums/tran...ml#post4649528
JamesC
Old Nov 22, 2013 | 08:49 AM
Engine: 305 (LO3)
I have seen that thread. It is fairly useful but seems to be flawed. The poly mount by nature will transmit more noise and any existing driveline vibration. No way around it. People replace only that mount and then blame it for the problems that arise when it could be a vibration due to an imbalance of the drive shaft or bad u-joints or bad angles due to lowering or possibly even worn out engine mounts - things that the softer rubber mount may hide. I didn't notice an instance in that thread where someone absolutely had everything right and still had a bad vibration when the only thing changed was the transmission mount. Mine is not going to be right, yet but I figure that I'll try it since a handful of people seem to not have problems.
I've also seen a lot about the replacement rubber ones failing much sooner than they should, even on unmodified cars. If I do have issues with the Poly, is there a particular rubber mount that lasts a reasonably long time? The one I will be replacing has a guaranteed 70,000 miles on it, probably more. I don't expect that out of a replacement, but to have to replace it once or more a year is not cool no matter how easy the job.
Old Nov 22, 2013 | 09:23 AM
Engine: L31 350
Iv installed the poly on my car and have no extra noise or vibrations. But iv got fresh motor mounts on my car and will soon have a new poly torque arm Mount and new joints. But I noticed nothing different about my poly trans mount
Old Nov 24, 2013 | 05:48 PM
Engine: 305 (LO3)
It's installed. So far, up to 80mph, no vibration or noise.
Old Nov 24, 2013 | 06:36 PM
JamesC's Avatar
Originally Posted by charliemccraney
Mine is not going to be right yet, but I figure that I'll try it since a handful of people seem to not have problems.
That's the issue, flawed or not. Some do, some don't.
JamesC
jhawkeye
May 25, 2022 06:33 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
Vintageracer
Jan 10, 2020 05:33 PM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
NBrehm
Aug 5, 2015 07:57 PM
