Transmission leaking fluid.
Old Jan 29, 2014 | 06:49 PM
Shadyredeyes's Avatar
Car: 1987 Camaro Iroc Z28
Engine: 350 S/B
Transmission: 700 R4
Axle/Gears: 2.43 Gear Ratio
I just recently replaced the rear seal and pan gasket on my TH350. I haven't driven the car at all, as it's too cold down here right now. Open the garage last weekend and there's transmission fluid leaking like crazy. I have not been under the car yet to see where it might be coming from. Anyone else ever had this problem? Or any any suggestions as to where it could be leaking from?
Old Jan 29, 2014 | 07:05 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Transmission leaking fluid.
The easiest thing to do is to get down on the floor and look.
Please describe your refill procedure. I think you might have over filled it.
There are numerous places fluid can leak out of; extension housing/case seal, speedometer gear, fill tube, TV cable, etc.
Old Jan 29, 2014 | 07:28 PM
Engine: 350 S/B
It's possible I might have over filled it. I filled it back up through the dipstick tube. I know this should have been done while the engine was running and transmission in neutral, but due to a dead battery I couldn't start the car. I also noticed the speedometer cable is non exsistent.
Hotrodboba400
Dec 10, 2019 07:07 PM
angel2794
Sep 8, 2015 06:22 PM
tgp1990
Sep 4, 2015 06:24 AM
jtwoods4
Sep 3, 2015 05:39 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
