Release bareing noise
Old Mar 8, 2014 | 07:34 AM
19irocz85's Avatar
Car: 1985 iroc z
Engine: Crate 350
Axle/Gears: 3:24
I just converted my 85 iroc to a 5 speed i put a fully rebuilt world class borg warner t5 in it i do believe i installed the release bareing wrong im takeing the trans back out to correct it tomorro but would it make a noise sounding almost like an output shaft bareing? It only does it with the clutch releaced in neutral, if i put any sort of pressure on the clutch it goes right away. Any advice? (Please dont judge this is my first 5 speed camaro, i made it a stick because i could not find one already done)
Old Mar 19, 2014 | 02:16 PM
gearheadotaku's Avatar
Car: '91 Firebird
Engine: 305 TBI w/LT1 cam
Transmission: T5 swapped in
Axle/Gears: 9 bolt 3.27 w/discs
Re: Release bareing noise
Yep, sounds like the t/o bearing. Make sure you use a good steel one from National. Most of the clutch kits come with cheapy plastic ones.
Thank you for putting a real trans in your car instead of the slushbox. I did the same with mine!
Old Mar 23, 2014 | 11:01 PM
19irocz85's Avatar
Car: 1985 iroc z
Engine: Crate 350
Axle/Gears: 3:24
I love the trans, shifts great lot more power and fast as hell but yea, i got a steel one the one in the clutch kit was steel to but i replaced it anyways and no more noise i got an f1 stage 3 clutch for 130 on ebay, its a 6 puc clutch so fat its great no complaints yet
Old Mar 23, 2014 | 11:09 PM
Joe Tag's Avatar
Just saw you solved it. NVM
RedLeader289
May 28, 2019 01:47 PM
jrdturbo
Mar 31, 2016 02:58 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
Fanatic1074
Oct 2, 2015 03:47 PM
sjorgens
Oct 1, 2015 07:54 PM
