Flywheel confusion.
Old Mar 24, 2014 | 11:44 AM
bygddy's Avatar
Flywheel confusion.
Hi!
OK so were are installing an early 350 with TPI in an 85 Olds Cutlass, I have a rebuilt T5 from an 85 camaro, I need a flywheel and am lost on why everything I find shows 83-85 specific flywheel?
Internally balanced small block, 153 tooth ring gear. So why wouldn't any neutral balanced 153 tooth flywheel meant for a 2 peice rm work?
Dave
Old Mar 24, 2014 | 12:31 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Flywheel confusion.
83-85 flywheels are for engines with the 2pc RMS. Either flywheel will work with the T5, but you need the one that matches your engine. 1pc RMS flywheels were used once that was changed starting in 86.
Old Mar 24, 2014 | 12:36 PM
bygddy's Avatar
And that's where my confusion lies, i have a flywheel, machined, 153 tooth, for a 2 piece rear, no idea what year its from, but does it really matter?
Old Mar 24, 2014 | 05:36 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
No
if it bolts to the crank you are fine
Old Mar 24, 2014 | 06:23 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Originally Posted by vetteoz
No
I'd add "and the pressure plate".
Old Mar 24, 2014 | 07:56 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Yes.
And the 83-85 lightweight flywheels aren't particularly unique.
The L88 in the late 60s used basically the same thing, 153 tooth and scalloped for light weight.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
