4L80E questions
Old Mar 29, 2014 | 02:23 PM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
4L80E questions
So if I use an earlier version, like a '94, I can use the cooler lines from a 700R-4? But it won't have all the bellhousing bolt holes to the block, but does that matter at 300 HP? Does it matter at 1000 HP? '91-'93 wiring was different, can I just grab the wires from a later 4x4 version? And is this issue inside the trans pan, outside the trans, or both? Would an aftermarket 2.74:1 low reduce the power capacity? Does it change the OD ratio? If not, how is that even possible? If so, what's the new ratio? 0.67:1, like the 200-4R? Is there an aftermarket 0.6x:1? Without getting a 2.10:1 first? How can the 2.97:1 first have the same 1.57:1 second gear as the 2.74:1? How is it not 3.0:1 like the TH400 it's based on? (Stock TH400s never had 3:1) And while Jake's gets all the acclaim, there must be other equally competent options, surely any of them would do if the car is traction-limited, right? If so, then I'm inclined to go with Performabuilt, not only for probably giving most of the answers, (I hope) but also for supporting this forum that I'm addicted to.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
