Where do clutch lines go? T56
Old Apr 15, 2014 | 12:00 PM
Buggy Disaster's Avatar
Car: 91' Z28. 70' Dune Buggy
Engine: LSX Cam/Full Bolt ons
Axle/Gears: 4.10
How does this work? The slave cylinder on my ls1/t56 has the two fittings for a line.
Where do I get this line?
Where does it go? Clutch master cylinder right?
I'm assuming I need two lines?
Sorry for my ignorance on this subject. Gotta learn someway right?
Thanks for any help.
Old Apr 15, 2014 | 05:58 PM
Pocket's Avatar
Car: 91 Trans Am
Re: Where do clutch lines go? T56
On the ls1 HTOB, upper port is bleeder, lower port connects to the master
The bleeder port should have either a long hex stub or line with a bleed screw on the end (speed bleeder)
The lower port should have a quick connect fitting. The line from the master to slave is quite expensive. I have a master/line Fs if you need one. Most vendors have speed bleeders available
IROCtometal
Sep 9, 2015 10:01 AM
jtwoods4
Sep 3, 2015 05:39 PM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
19irocz85
Aug 30, 2015 10:03 PM
