How do I wire Torque Convertor Lock up to a Toggle Switch?
Old May 23, 2014 | 11:38 PM
zz3irocz's Avatar
Car: 1986 Iroc Z, red, t tops
Engine: Gm Performance ZZ3
Transmission: Built 700 r4
Axle/Gears: 3.73 Detroit Locker 10 bolt
I have spent the last three hours trying to find the answer, and have seen 20 different ways it's supposed to be done. I have an 86 Camaro with no computer, I have a tan wire, purple wire, and a blue wire coming from the transmission. The purple wire has been hooked to constant 12 volts by a previous owner, I want to run the lockup with a toggle switch for now.
So how do I wire this so I can lock it up in 4th gear.
Old May 24, 2014 | 02:13 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: How do I wire Torque Convertor Lock up to a Toggle Switch?
Run the tan wire to ground through a switch and you can lockup any time you want
You can get the same result by running terminal F on the ALDL through a switch to ground
The purple should run from the TCC switch on the brake pedal as per stock setup so the lockup drops out when you brake; even if the switch is on
Old May 24, 2014 | 09:48 AM
zz3irocz's Avatar
If I twist the blue and tan wires together would that give me lockup in 4th gear only? The transmission wires are cut off by the firewall so I don't know where they originally went to.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
355sbcTPI
Aug 19, 2015 04:38 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
