Vibration noise when in reverse only
Old Jun 7, 2014 | 04:00 PM
graysmoke's Avatar
Car: 91 Convertible
Engine: Stock 305
I have a vibrating noise from the passenger side area with car idling in reverse with my foot on the brake at a stop. If I take my foot off the brake and let it roll in reverse at idle speed it goes away. When I apply the brakes it returns. I do not get this noise in drive or in neutral or park or while driving. If I revv the engine in park I do feel a mild vibration but does not cause this noise. It started a couple of weeks ago and I thought it was exhaust vibration. I figured it clear itself after I had my exhaust work done. Well I replaced everything new- y-pipe, cat to muffler and its still there. any thoughts on this?
Old Jun 7, 2014 | 06:44 PM
NowhereFast's Avatar
Car: 87 Trans Am, 99 WS6, 16 Mustang GT
Engine: LB9, LS1
Transmission: 700R4, T56
Axle/Gears: 3.42 Posi, 4.10 Posi
Re: Vibration noise when in reverse only
Do you have SFCs?
Old Jun 7, 2014 | 08:26 PM
graysmoke's Avatar
Car: 91 Convertible
Engine: Stock 305
Originally Posted by _Nick_
Do you have SFCs?
Yes. Its new 3"
Old Jun 7, 2014 | 09:05 PM
a62belair's Avatar
Car: 88 Firebird, 87 Formula
Engine: 2.8, 5.0
Transmission: both 700R4
Axle/Gears: 3.42,3.45
Headers and aftermarket exhaust? My y-pipe would bump the subframe in reverse only, until I adjusted it.
Old Jun 7, 2014 | 09:12 PM
Engine: LB9, LS1
Originally Posted by graysmoke
Yes. Its new 3"
I guarantee the Y-pipe is hitting the brace that goes from the SFC to the frame near the transmission tunnel. When you put it in reverse, the motor torques the exhaust into it, creating that heavy vibration and occasional noise.
My car does it too since I had the sfcs put in, I'm just glad it doesn't happen while driving.
Old Jun 7, 2014 | 10:03 PM
graysmoke's Avatar
Car: 91 Convertible
Engine: Stock 305
Nick, I hope that's the problem. I'm gonna take it back to the exhaust shop Monday. I just don't understand it being the same before and after I had the exhaust work done. The exhaust before was factory. That's what has me confused. I checked, does have about 1/2" clearance to frame.
I have stock manifolds but probably same issue. Thanks.
db057
Jan 10, 2020 08:55 PM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
roysatikas
Sep 22, 2015 08:15 PM
InfinityShade
Sep 18, 2015 08:32 PM
