t56 swap help
Old Jun 22, 2014 | 07:08 AM
camarozz383's Avatar
Car: 1989 camaro rs
Engine: ls 5.3 carb
Transmission: t56 six speed
Axle/Gears: 3:73
t56 swap help
hey guys Im going to ask a few questions that I'm sure have been asked already, if someone can point me in the right direction that will help.
ok I just bought a t56 with a quick time bell, pro 5.0 shifter, tick master, and speed bleeder, its going on my 5.3 carb swap, can you tell me what sensors or plugs I need to fit this up, thanks
Old Jun 22, 2014 | 08:22 AM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Re: t56 swap help
Google can be your friend, too!
Reverse lights - middle of case on passenger side.
Skip shift - ignore it. You can get a freeze plug to replace the solenoid. Driver side, top, forward of the two solenoids.
Reverse lockout - driver side, by the shifter, rear of the two solenoids.
VSS - driver side, below shifter.
Old Jun 22, 2014 | 08:56 AM
Car: 1989 camaro rs
Engine: ls 5.3 carb
Axle/Gears: 3:73
Re: t56 swap help
OK so I don't need the skip shift, but I need the Reverse lockout and obviously the vss, and reverse light switch, that's exactly what I needed! pics and a good explanation is always good, thanks so much
AussiePr0nCar
Mar 6, 2020 04:04 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
19irocz85
Aug 30, 2015 10:03 PM
19irocz85
Aug 26, 2015 07:54 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
