Changing Rear End
Old Jul 25, 2014 | 07:48 PM
25thSwappedRS's Avatar
Changing Rear End
I have a 1992 camaro rs with an older 350 v8 swapped in. It was rebuilt a few thousand miles ago, was bored 30 over, has hypereutectic pistons, edelbrock performer 750 carb, edelbrock rpm intake, world product 2.02/1.60 heads, hedman headers, straight pipes with cat delete, 2500 stall, turbo 350 with a shift kit and ratchet shift. It has the stock 2.73 rear end and i want to change it to a 3.73. I'm a major noob when it comes to this and i don't know what i need to do the change, besides the gears obviously. Help?
Old Jul 25, 2014 | 08:40 PM
big gear head's Avatar
Re: Changing Rear End
https://www.thirdgen.org/forums/tran...axle-gear.html
Old Jul 25, 2014 | 08:52 PM
Originally Posted by big gear head
Much thanks
Old Jul 25, 2014 | 09:18 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Here's what I had done = https://www.thirdgen.org/forums/tran...de-photos.html
Old Jul 25, 2014 | 09:48 PM
Originally Posted by Ron U.S.M.C.
Was it worth the money?
Old Jul 26, 2014 | 07:27 AM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
I did much of what Ron USMC did to his 10 bolt (I added LPW Brace and solid pinion spacer).... at the same time I also switched out to Founders LCA's with 3 way poly joints.... yes, it was expensive, but due to all new parts, the car rides so much smoother / less harsh than before (like my Honda Accord)(I have Bilstein's and Subframe connectors, etc...)
My neighbor has a 89 305 TPI Iroc... 2.77 rear.... I gave him my old rear end... It was out of a 91 Formula 5 speed, 3.42, Posi, 28 Spline axles, he Loves it!
If budget is limited, get a 3.42 out of a 90 - 92... they have the 28 spline (stronger) axles, before then they had 26...
To go from a 2.77 to 3.73 you would need all new internals, since they are different series...
Rafael
Old Jul 26, 2014 | 10:01 PM
Engine: TBI,5.0
From a 2.73 with open differential to a 3.42 with an Eaton posi.
Every penny !!!!
A one wheel peal = ????? Fill in the blank ...............
Dual tire burn and hook = Sweeeeeettttt
Old Jul 26, 2014 | 10:19 PM
Every penny !!!!
Honestly i mean my camaro is fast enough to put down most of the cars on the street as it is... its fast. But it has not been tuned since it was rebuilt, it has a stock camshaft, and the stock 2.77 gears and open diff. People tell me to roast them and the best i can do is a unicycle burnout lmao.
On top of that the open wheel's tire is nearly bald. I cant imagine how fast this car could be if i change those few things.
I also have an MSD 6al box laying around here that i should probably install.
Old Jul 27, 2014 | 01:21 PM
2.77? Do you have the 9 bolt rear end? If you do then that's completely different. You must be sure of which rear end you have before you get started on this.
Old Jul 27, 2014 | 01:28 PM
Actually i'm not even sure anymore. The guy originally told me it had a 2.77 and i thought it was a 2.73 but now i'm seeing other things online. I'll just have to look when i get home.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
