Dakota SGI-5 C & Samoco wiring help, TBI with T56 swap
Old Aug 2, 2014 | 12:01 PM
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
Guys, I've searched and read lots of threads on here and read the instructions but need help. Put a T56 in my '91 firebird with a 5.0 TBI. Installed dakota & samoco boxes but can't get the speedo to work properly. I removed the buffer box and used the wiring to the buffer box and have the VSS inputs correct with the Samoco box wired inline. I have 2 outputs from buffer, one to speedo and one to ECM. Based on the dakota instructions, the 4000PPM (output 5 on box) goes to the speedo, 2000PPM to the ECM (output 4 on box). I haven't read anything on here though about 2 outputs from box with the exception of this thread, which is what I followed - https://www.thirdgen.org/forums/elec...r4-dakota.html. Also, power light starts to blink when car is moving, is that correct? Any help is apprectiated.
Attached Thumbnails Dakota SGI-5 C & Samoco wiring help, TBI with T56 swap-dakota-box.jpg   Dakota SGI-5 C & Samoco wiring help, TBI with T56 swap-dakota-samoco-boxes.jpg   Dakota SGI-5 C & Samoco wiring help, TBI with T56 swap-diagram_1992_vss_v8_vine.jpg
Old Aug 5, 2014 | 03:12 PM
dellman83Z's Avatar
Car: 87 monte aerocoupe
Engine: 383 HSR w/ novi 2000
Transmission: Built 4l80e circle d converter
Axle/Gears: Currie 9" 3.89 gears
Re: Dakota SGI-5 C & Samoco wiring help, TBI with T56 swap
I have mine with the first two dip switches down and the last two up. Output 5. Also running straight off the sensor to the dakota box, then to the speedo which is also a 4th gen dash. Hope that helps some. Mine like this works great.
Old Aug 8, 2014 | 08:08 PM
Ed1LE's Avatar
Engine: 5.7, 5.0
4th switch needed to be on, seems to be working like a charm now.
Old Aug 8, 2014 | 09:31 PM
dellman83Z's Avatar
Awesome glad you got it working
xkingcodex
Feb 12, 2020 07:43 PM
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
jharrison5
Aug 19, 2015 05:53 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
