converter lock up question
Old Sep 1, 2014 | 01:25 PM
zapr's Avatar
Car: 1985 camaro z28
Engine: 305 lg4
I installed an edelbrock performer rpm. Since then, I've lost torque converter lock up. Any ideas. Thanks....Zapr
Old Sep 1, 2014 | 07:42 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: converter lock up question
Did you just swap the intake manifold or did you also swap the carb?
Did you reset the TV cable?
Old Sep 1, 2014 | 10:59 PM
zapr's Avatar
Engine: 305 lg4
Swapped intake, kept the q-jet. The throttle bracket doesn't fit the same. Wondering if when I adjusted the tv cable if it pulls out further because the carb sits higher. Would that cause me to lose converter lock up or is it a switch. Thanks....Zapr
Old Sep 2, 2014 | 05:49 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
You need to make sure that the TV cable is set properly. Once you know this is set correctly you can chase other possible causes.
http://www.700r4l60e.com/forum/viewtopic.php?f=19&t=10
TCC lockup is controlled by the ECM and not the TV cable.
Old Sep 2, 2014 | 08:09 PM
zapr's Avatar
Engine: 305 lg4
Non computer Canadian car. I adjusted the tv but have not driven the car yet. I'll let you know. Thanks for your help.....Zapr.
Old Sep 6, 2014 | 01:37 PM
zapr's Avatar
Engine: 305 lg4
Drove the car. Holds the gear to long. No converter lock up.....Zapr.
Old Sep 6, 2014 | 05:16 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
export models use a vacuum source to determine load for lockup. look for a vacuum line that isn't hooked up or loose somewhere.
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jake_92RS
Aug 17, 2015 09:42 AM
redmaroz
Aug 16, 2015 11:40 PM
