85 TA rear end on an 88 Formula?
Old Sep 11, 2014 | 03:41 PM
tyeo098's Avatar
Car: 88 Chimera
Engine: 1994 LO5 5.7L
Axle/Gears: 2.73...?
Local guy is selling a 85 'WS6' TA disc brake rear end (axel, diff, rotors, pads, etc) its in a bit of a rough shape from sitting outside for a while, but my 88 Formula has drum brakes on the rear.
Are disc brakes that much better than drums to warrant the 50$ he wants for the rear end?
Will the rear end from an 85 TA even work on an 88 Formula?
Thanks!
Old Sep 11, 2014 | 03:42 PM
tyeo098's Avatar
Car: 88 Chimera
Re: 85 TA rear end on an 88 Formula?
Attached is the picture he sent me...
Attached Thumbnails 85 TA rear end on an 88 Formula?-00u0u_atvw9vn4wav_600x450.jpg
Old Sep 11, 2014 | 04:00 PM
Irockthedrag's Avatar
Car: 1983 Z28
Engine: Turbo LSX
Transmission: 4l80e
Axle/Gears: 10 bolt torsen diff 3.73
Do you even know what gear ratio is in the other rear? What kind of shape is yours in?
Old Sep 11, 2014 | 04:09 PM
tyeo098's Avatar
Car: 88 Chimera
Mine is rusty and leaking gear/brake fluid. (both, not or)
Inquiring about the gear ratio now...
Why is there no 'factory standard' for these parts, everything seems to vary...
Old Sep 11, 2014 | 05:13 PM
big gear head's Avatar
The disc brakes are not really any better on the street. The '88 is going to have the crappy cast iron calipers. I wouldn't bother. You are going to have to change some other parts to make them work. It will probably cost you several hundred dollars to get everything fixed and working right. If it was a '90 to '92 rear end then I'd say go for it.
Old Sep 12, 2014 | 03:09 PM
tyeo098's Avatar
Car: 88 Chimera
Email I got from him:
It does have a tag on the cover that says "Limited Slip Gear Lube Only" so it's pretty likely a LSD.
My car with the drum brakes is the 88, the rear end is from an 85 with the disc brakes. Does that make a difference?
Old Sep 12, 2014 | 05:33 PM
The '88 will be the 7.6 and the '85 will be the 7.5. Both will have 26 spline axles. Those disc brakes are not really an advantage.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
