t5 replacement cutch. mystery pipe
Old Oct 2, 2014 | 01:28 PM
dexyman's Avatar
Car: 1991 transam
Engine: 305 tpi
Transmission: t5
so i pulled my t5 this afternoon as clutch is no good
thought i had disconnected everything but when i removed the trans from the bellhousing there is a black pipe on top of the trans
is this a breather pipe, where does it go ?
any tips on removing the bellhosing bolts as they look not too accessable
Old Oct 2, 2014 | 01:35 PM
pound's Avatar
Car: 1990 Firebird
Engine: 350 TBI
Axle/Gears: Auburn posi 3.73
Re: t5 replacement cutch. mystery pipe
There is a small breather on top of the T5. Every one I've seen has been a little stub maybe only a few inches in length. The bell housing bolts you can get to with some extensions. You might have to use a u joint or the extensions that allow the socket to rock slightly.
Old Oct 2, 2014 | 01:45 PM
dexyman's Avatar
Car: 1991 transam
Engine: 305 tpi
Transmission: t5
pipe is around 12 " long
Old Oct 3, 2014 | 08:06 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Yup breather and it goes on top. One T5 I had just used a nipple the other had the pipe.
Orr89RocZ
Apr 25, 2016 08:28 AM
transaero
Aug 31, 2015 01:14 AM
TheExaminer
Aug 26, 2015 04:59 PM
db057
Aug 22, 2015 08:17 PM
Out-Cast
Aug 22, 2015 07:49 PM
