Flywheel for T56 swap
Old Jan 9, 2015 | 09:21 PM
mcweens's Avatar
Car: 1987 IROC-Z & 1991 RS
Engine: IROC-305tpi & RS-357(built)
Transmission: Both-700R4
Axle/Gears: IROC-3.23 & RS-4.10
I have a 1977 350 motor in a 91 Camaro. I am swapping the 700R4 for a 1997 T56 transmission, but I am confused about what type of flywheel I should use. The Tranny came with the flywheel from his 97 Camaro LT1. The 350 has a 2 piece rear main seal and I believe it is an internally balanced motor, but I do not know if the motor was ever balanced after its rebuild. The previous owner provided limited information about the motor. Can I use the flywheel from the LT1 or does this mean I have to use a neutral balance flywheel? Any and all help is appreciated.
Old Jan 10, 2015 | 02:21 AM
RamIt's Avatar
Car: 1984 z28
Engine: Crate replacement L31R 350
Axle/Gears: 7.625" 28 spline 3.23
Re: Flywheel for T56 swap
https://www.thirdgen.org/forums/tran...-flywheel.html
Old Jan 12, 2015 | 04:51 PM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
U can not use the LT1 flywheel since that is a 1 piece rear main seal u need the custom flywheel that cost around 400-500 bucks
BlackphantomZ28
LSX and LTX Parts
Oct 19, 2015 06:25 PM
19irocz85
Aug 31, 2015 10:31 PM
BlackphantomZ28
Aug 31, 2015 10:29 AM
19irocz85
Aug 26, 2015 07:54 PM
sreZ28
Aug 14, 2015 07:48 PM
