what year(s) 4l60e with 427 pcm
Old Mar 23, 2015 | 02:37 PM
gilly327's Avatar
Car: 86 firebird se/91 camaro rs
Axle/Gears: 3:73/3:42 4th gen
im looking into getting a 4l60e transmission.The pcm im using is a 427 from a 95 suburban.just trying to see what everybody else running them is using or recommends thanks
.1993- first year for the 4l60-E. In its simplest terms, it is an electrically controlled 700r4. No PWM. 11 pin connector
1994- NOTHING changed between 93 and 94. Transmissions are directly interchangeable. No PWM. 11 pin connector
1995- Stand alone year. First year for PWM. Has an extra solinoid to control the PWM. 3-2 shift AND TCC are PWM in this trans. Has a different 3-2 control solonoid, and a extra wire in the harness to facilitate the PWM TCC lockup. Addition of a trans mounted neutral safety switch. If you put a 95 trans in a 94, it will not recognise the PWM circuits and will go in to limp mode. If you put a 94 trans in a 95, the check engine light will stay on, and the TCC and the 3-2 clutch pack will burn up after just a few miles. If you put a 96 trans in a 95, the 3-2 clutch pack will also burn up after a few miles. 95 has a 10-15 ohm TCC solenoid and a 10-15 ohm 3-2 solenoid. 12 pin connector.
1996- 3-2 shift is NON-PWM. It was changed back to a on/off arrangement. The 3-2 solenoid was changed to a 20-31 ohm unit. The 3-2 control valve was changed to "design 2". TCC is still PWM and uses the same 10-15 ohm solenoid as a 95. You can create a 95 trans out of a 96 or vice versa, but you have to change the 3-2 solenoid, the valve body, and the separator plate. If only the 3-2 solenoid is changed (and not the valve body casting), the transmission will 'cut loose' on 3-2 downshifts (shift from 3rd to neutral, then to 2nd as the accelerator is released). 12 pin connector.
1997 (one piece bell housing)- Identical to 1996. Direct swap. 12 pin connector.
1997 (two piece bell housing)- Identical to 1996 EXCEPT the addition of a transmission ground wire in the harness. This was done to address poor transmission grounding issues on the previous models. Can be interchanged with the 1 piece bell housing, but the ground wire should be added to the harness if you are using the 2 piece. 2 piece bell housing models also had hardened sun shells to address the sun shell fracture issue common to the previous model automatic transmissions. Identical in fit, function, and design, the material just changed. 13 pin connector.
1998- Identical to 1997 2 piece bell housing.
1999-up Identical to 1998 and 1997 2 piece bell housing
Old Apr 6, 2015 | 08:31 AM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Re: what year(s) 4l60e with 427 pcm
Good researching, but any '95-'97 will work. Because your PCM expects PWM, any 60e capable of PWM will keep the PCM happy. What you listed were PCM strategies, not 60e capabilities.
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
C409
Sep 1, 2015 03:42 PM
NBrehm
Aug 25, 2015 11:49 PM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
