need rear end advice
Old Mar 31, 2015 | 10:47 AM
87FBomb's Avatar
Car: 1987 Firebird
Engine: LG4 305
I have a 1989 formula 350 that I'm going to put vortec heads with either a super ram or edelbrock pro flo xt intake I'm thinking about installing a comp cams 276hr I'm going to run a megasquirt3 setup with sequential injection and ignition using a 96-02 cam sync distributor and a 24x reluctor wheel from efi connections. What gears should I use if I retain the 700 and what would you recommend if I went to a 4l60e this will be a weekend driver maybe some track time nothing serious
Old Mar 31, 2015 | 06:47 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: need rear end advice
The low first gear in the 700R4 doesn't like a deep gear in the diff. Something in the mid 3.xx range works well.
Doesn't the 4L60E use the same ratio?
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
